Docwits
Need y'alls help with trying to figure this out. Installed new wiring harness from Mike's and upon turning the key got no power. No power going to the main fuse. Jumped the main fuse from the battery and everything works fine. Took apart the wiring harness to the fuse box and found the two blade connections for the main fuse were disconnected just before the wiring meets the main harness. Reconnected and all is good, or is it.
My question is does anyone know which end of the fuse is "in" and which is "out?" Does it matter? I don't want to run the bike without the protection of the main fuse.
One wire from the fuse panel connects to another red wire, and the other is red with a white stripe. I looked at every wiring diagram I could find, with no luck.
If anyone knows, could you please answer in the form of "The wire on the side where the wires enter the panel (bottom in the picture) connects to the red and white wire", or the wire on the side they enter (bottom of pic) goes to the battery.
Thank you all in advance for your help in this manner.
