ryan79
trying to get pics up is harder then fitting this front end on.pain in the ass. I have more pics of this project but need to get through the computer ,posting stuff learning curve. front end is 2005 r6 usd forks, wheels are from kawasaki er6n, swing arm is tt500 from grand prix speed works, holds a 160 rear no problm and is same lenth as radian. plops right in.sold the radian swing arm for close to as mch as the price as this one.it super light and cromoly,that was a no brainer.front end is just about done,wave rotors are finly lined up in between to calipers. had to remove 1 mill on each side of hub.steering stem takes two bottom xs650 size bearings to fit. what luck. just need to press out bottom spacer. the back sprocket was a peace of cake. thay make a 34 tooth that fits the same bolt pattern for one of those work type four wheeler thingys. just needed to do little reaserch to match it. 25 bucks 520 width and steel . it should be off the sling this weekend and rolling. sucky part is when im done I get to tear it all down and paint the frame again. I can,t get into the silver anymore.
