bennecc
I noticed that I've got a pretty good oil leak from the lower bolt on the front cam chain guide. The leak seems to be coming out of the smaller bolt that fits into the other bolt. All the copper washers are in place. The threads on the guide inside feel stripped....it is definitely on the guide but there is no resistance when I turn the bolt.
The upper bolt is fine, so the cam chain guide should be stable, I would think.
I've never used one of those helicoil things. Would something like that be usable in this situation where the damaged threads aren't readily accessible? My other thought was to just epoxy the smaller inner bolt to the larger one and worry about it next time I have to tear into the engine. Not sure if that would hold up to the heat though.
The other option is to go ahead and replace the cam chain guide. Does that require pulling the motor?
