Shes alive!!!
So basically, I started taking apart the advance unit and i found that the pin is the one that sits behind the larger plate unit (the one that keeps the entire assembly from spinning on its own)
Essentially what must have happened is, the large flat cogged nut must have came loose, which allows the large rear plate to wobble. When this wobbled, it allowed the rear locating pin to slide underneath and shear the entire thing. (as seen below)
I ghetto rigged it back together to see if it fixed my issue and it worked!
Its obvious I need to re-tune the carbs because its not idleing the best with the new pilot jets.
So now I just need replacement parts.
Mikes 14-0652 part looks like what I need however it says "contact point ignition assembly".... Will this still work?
