1. Dismiss Notice
    Dismiss Notice
swingarm issues.
Discussion in 'The Garage' started by koyuga, Dec 6, 2017.
  1. koyuga
    koyuga XS650 Enthusiast
    Purchased a downward off eBay.
    Read on the web about some guy welding up the gaps in the plate near the pivot.
    Got the local fab shop to weld it up.
    Fitted it on the bike but the wheel and spacer won't fit.
    Measured the internal axle width at 207 mm.
    My old axle is 225.
    Could it have shrunk.
    Or is it off a 400.
  2. koyuga
    Frickin autotext.
    Swing arm has shrunk
  3. TwoManyXS1Bs
    Anybody wanna take a guess at what word was replaced with "downward"?
    I got nuttin'
    Try forum searches on "spread axle plate" and "spread swingarm"...
  4. angus67
    angus67 Welder's penetrate deeper!!
    Swingarm
    gggGary likes this.
  5. koyuga
    Thx. Yeah swingarm.
    Will try spreading axle.
    Cheers.
  6. 650Skull
    650Skull SSSSSSSSSlither Top Contributor
    Bloody axle will be hard to spread.............wouldn't try it on a swing-arm either..........
    post some pics and we can identify if it is an XS650
    gggGary likes this.
  7. gggGary
    gggGary I'm listening, change my mind XS650.com Supporter Top Contributor
    Yeah the welding coulda done it. Not sure why you would weld those gaps shut. That gap wasn't a cost saving measure. do some search on stress risers, fatigue cracking. Then; if the arms have moved it's likely the pivot bushings are no longer in alignment or round? typically critical bores like that are final bored AFTER the swing arm is welded up.
  8. azman857
    azman857 '80 XS 650SG Rider XS650.com Supporter Top Contributor
    If you are going for looks, I'd brace it. Sporty looking and practical.
Share This Page
