Punkskalar
Hugh's HandBuilt
Finally got some time to mess with Tevan's Resto-Mod Cafe' project. Since he is using a 71' Chassis, we knew would need to stiffen some things up. We will focus on the rest of the frame later, but for now, here is what we did to the swingarm..
I've been showing Tevan how to bend and notch tubing, but it was finally time to let him try it out for himself... Armed with some 7/8" OD tubing, an angle finder and the bender, he managed to get the upper truss/brace bent up in one shot...
The notching took a while to make it all fit properly, but his patience has paid off... I think he may have practiced on about 4 feet of tubing before he was finally comfortable with his notches...
Careful consideration was given to proper chain clearance and shock clearance. We had to double/triple/quadruple check the frame clearances as we went...
All welded up... TIG on 40 year old steel can be a real challenge, but we managed...
The factory had some fairly gnarly looking welds, so we cleaned up what we could... Not perfect by far, but much better than it was
We are cleaning up the old frame now, and might even get some time to make the tail section mounts here today...
