Moose12
Hi! I have a 1977 xs 650. Looking to switch over to pod-style air filters. How do I select ones that will fit and work right. Running BS38 carbs.
I recently bought my 2nd '76C in French Blue. Aside from a non '76 brake master cylinder and a '78-79 stepped seat, it appears to be stock.
Plan to repaint to red scheme, but lots of mods to do before then.
Popped off the side covers today, pulled off the airbox covers and removed the filter cartridges. There was nothing but metal frame left in either filter. Not even a hint of paper, foam, etc. PO's....
On my first '76, I eventually removed the factory airboxes and went with 4" Uni (pod) Filters.
Are there any "Airbox Enthusiasts" out there who can convince me to stick with the airboxes and dissuade me from going the Uni-Filter route again? I still have a pair of K&N OEM Type pleated filters (YA-1152) on hand.
I've got a comparable ignition question regarding sticking with points, condensers, etc. (at minimum, I plan to swap out weak coils) and not converting to Pamco, but that's a different thread...
I like my bike to stay as close to stock appearance as possible. I only change things to increase reliability and safety. Yes, I admit it, I'm an airbox enthusiast I use stock type foam air filters. I like the fact that the crankcase vents back into the stock air boxes.
When I bought my bike, the first thing to be removed was the buckhorn bars, and the second thing was the old stock ignition coils. I ran the first year using points, but used a single dual output Accel coil. I used a 1.2 ohm ballast resistor in series with the 3.3 ohm Accel coil, and both sets of points tied together in parallel.. The second year I changed over to a Pamco ignition. I'm still using the same Accel coil, with the Pamco, but of course, without the ballast resisitor.
For anyone that just loves points and likes to fiddle with them, I say knock yourself out, and keep running points. With a good strong coil, points work just fine.
When I changed over from points to a pamco, I could not detect any difference in performance.
I appreciate your comments, rg.
As much as saving $, I'd like to learn how to fiddle with points. Would it be better to go with a 1 dual output coil rather that 2 OEM Style coils if I stay with points ignition? My eyes glazed over after reading your 2nd paragraph , but I'm sure I can wire them up right eventually.
I need to search/read some posts on points ignitions and how to manage them. Videos would be nice.
I have yet to remove, disassemble and clean the carbs on my latest 650, but need to. The familiar odor of stale fuel (varnish, actually) tells me the BS38's need a good cleaning. Yes, that's a great guide. I've got it printed out, tabbed and in a 3-ring binder.FWIW I just switched to Uni pods and am glad I did. The cost of replacement filters for the stock airboxes is just about the same as the Unis (UP4200 for BS38s) and a handful of jets. Great excuse to crack open your carbs if it hasn't been done already- I discovered a leaky float when doing mine. There is an excellent carb guide (http://www.amckayltd.com/carbguide.pdf), I highly recommend reading this all the way through before tackling the job. I had never done something like this before, and am glad I did. Feel much more confident tuning/troubleshooting carb issues now.
