wallywheels
"savage"
Ok A few days ago, a bike I helped a friend build was finished and all was well until the volt sensor wire came disconnected form the reg/rec and caused a spike in voltage. I believe around 18v was as high as it got. Then the bike died. I fixed the disconnected wire to the reg/rec and went on to try starting again and no spark. I traced wires until it lead me to the TCI box and I swapped it out for a good one I had. WALLA!! it fixed it so I knew it was the ignition box. I took it apart and found a melted capacitor and a bubbled Transistor so I did some research and found the matching parts from www.digikey.com Here is what I replaced
Transistor part # MJE5742GOS-ND
Capacitor part #P15798CT-ND
I have also read the 4 resistors D1-D4 can go bad but mine has good resistance so no need to replace at this time.I put it back in the bike and it had great spark and runs great!
