Rez Fink
Ok so now i have a PO story...
After doing some work to on the cam chain was putting the heads back together and started the engine and its starts up and I'm a happy camper. I notice oil dripping out slowly from the bottom of the OIL DELIVERY TUBE. I take of the deliver tube and I start to loosen my bottom banjo bolt and it is a MF'er to loosen. I start to tighten it slowly/gently to get it back on track with the threads. I can already feel its not threaded right. So i go back and forth trying to get it to move one way or the other. It finally is just spinning and not going either way.
so i pry up the banjo bolt with a screw driver and and loosen it out. the threads on the engine are toast. so I'm on my way to get a tap to try and repair it. but i feel that theres not enough meat to make new threads/grooves.
can i use teflon tape on the bolt and thread it on carefully? there are a minimal amount of threads on the engine toward the top of the hole.
i figure that its not a high pressure line (i don't think) so teflon could work to keep it from dripping.
