highboy_coupe
I was wondering if there's a reason why many owners report that the cam chain adjuster washer is missing?
I mean, why would a PO take the rod out completely, why would they remove the washer, and why wouldn't they care to replace it?
Mine was gone, I found a rubber washer that fit, but I am aware that I probably can't use the rod/housing being level as my setting anymore because the thickness of the washer is not right, so I just eye up when the rod is moving in and out least with the motor running.
I still have a noisy clacking engine, my intake valves are slightly loose at 0.0031 (only have a 6mm or 8mm feeler gauge)
