Todays question would be asking about the diode that’s in the main harness, under the tank and next to the condenser mount. Does that have anything to do with the turn signals?
IIRC, it's the headlight.Todays question would be asking about the diode that’s in the main harness, under the tank and next to the condenser mount. Does that have anything to do with the turn signals?
I now do this too. Good idea or bad to apply dielectric grease to the end before screwing the cap on?When you install the new plug caps, prep the ends of the wires like so. This will insure a good connection. Coil end of the wire should be done this way as well .....
Don't get dielectric grease on the conductor. It's an insulator.I now do this too. Good idea or bad to apply dielectric grease to the end before screwing the cap on?
I was wondering because when I turn the blinkers on something under the tank buzzes. That’s all I remember being under there besides condensers and I don’t think it’s them. When my RA filters come I’ll look under the tank and see.IIRC, it's the headlight.
Found them here.Save the tin shrouds that cover those old intake manifolds as they are N.L.A. and should be used for added support, especially if you run pods.
