member3480
RICH
OK guys I said I would try and make up a couple wire harness kits in APRIL. So I have three done and ready to ship. I changed them up a little and now have a 12 pin plug so you can make up your switches or extend the wires to stock controls.
THIS IS WHAT IS THERE
3 WIRES FOR HEAD LIGHT HIGH/LOW/GROUND
3 WIRES FOR TAIL LIGHT RUNNING LIGHT/BRAKE LIGHT/GROUND
2 WIRES FOR HORN HOT WIRE / GROUND
2 WIRES FOR BRAKE SWITCH HOT WIRE/WIRE TO TAIL LIGHT (plus I left a tail if running front brake)
2 WIRES 1 FOR PAMCO/BOYER/TCI- If running POINTS you only use one /OTHER WIRE FOR COIL
1 WIRE FOR NEUTRAL LIGHT
ALL WIRES TAGGED and SHRINK WRAPPED
ALL GROUNDS RUN TOGETHER for one MAIN GROUND
THIS IS A KIT YOU HAVE TO ADD SWITCHES AND FINISH
For a add on I also have TURN SIGNAL KITS TOO
Left/right wires with wires for stock handle bar switch and hot wire for FLASHER
ADD on to kit $20.00 or by itself for $30.00 Shrink wrapped and tagged SHIPPED FREE IN USA
I have sold these to be used on XS650/CB750-650-450/KZ750-440/GS400/Triumph/BSA
AGAIN I GOT 3 RIGHT NOW READY TO SHIP!!!!
$50.00 SHIPPED IN USA OVERSEAS I WILL GIVE YOU 20% discount BECAUSE you have to pay shipping..
I will try and make three more up in the next two weeks.
THANKS FOR LOOKING
I GOT TIME TO DO TWO CUSTOM HARNESSES so if you are interested in a custom harness with switches/fuse block/Key switch contact me at DADDYGCYCLES@YAHOO.COM
ADDED PICURES OF HARNESS KIT-TURN SIGNAL ADD ON with RUNNING LIGHT-FULL HARNESS
THANKS FOR LOOKING
