Hi,
Thought I'd throw this out to anyone rather than dump this on RetiredGentleman.
Question: How far to the left of the advance mark can the timing be before damaging the piston?
Background: I just finished a top overhaul on a stock '77D with 28k. The points and backing plate were clean and still serviceable. The bike was running very well for a few miles until the advance mechanism backing plate retaining nut loosened itself and the cam pin fell out. While dealing with that, I came across RG's advance weight tang peening tip, and tried it (I also clipped the new springs as they were too loose). It worked great! Bike never ran smoother. Initially I had used the static method to set the timing at idle and left the rest to itself because the bike ran so well to redline. RG was very kind in reminding me to check the timing with a timing light to ensure the spark wasn't advanced too much at higher rpms (excessively advanced timing = holed piston). Hooked up the timing light and at idle, the timing was exactly centered between the two marks on either side of the "F". Sweet, huh? Rolled the rpms up to 3500 and the timing moved to a spot 1/2" to 3/4" LEFT of the full advance mark, giving the appearance of too far advanced. Bike still sounds very good. If it matters, the mark shown by the strobe didn't really move off idle until around 3000 rpm and it jumped out past full advance suddenly, in a second or so. Rotated the points base plate to time idle at the right hand mark beside the "F" hoping to retard the timing closer to the advance mark and still get a decent idle. The advance moved in to about 1/4" LEFT of, but still beyond full advance. The bike ran okay, but the idle wasn't as good. I did not recheck point gap. I rotated the base plate back where it was and the timing settings returned to their original positions relative to the marks. I then pinned one of the advance weights to full out (the other moved with it the same amount) and static timed both points. Without doing any adjustment, both were 1/8" - 1/4" to the RIGHT of the full advance mark, indicating very good advance I have put about ten miles on the bike since the overhaul. Running Iridium plugs which I have not checked for color. 87 octane with no pinging or sounds of preignition (not that I would necessarily recognize it unless it was really bad). The bike, as it sits, is a sweet little rocket that wants to GO.
So any advice will be appreciated... Is it safe to run? Only the weights showed any wear, but should I replace the entire advance mechanism? Should I replace the mechanism, lose the points for a PamCo and cross my fingers? (I think I know the answer to that one, but I haven't done enough reading to understand how the PamCo will prevent holing a piston in this case) I will do the PamCo sooner now rather than later, but I really want to know what the heck is going on.
BTW, I do value two cents, so THANKS for any help (and/or humorous comments)!
