No, I wouldn't change it to the center "F" mark. Your timing is slightly retarded and that's a good thing. It will insure you don't over advance, protect against pinging, and many of us feel the motor actually performs better with the timing set like this.
If you wanted to fool with something, the only thing I might change is to try to get both cylinders firing closer to the same spot. I would change the cylinder that is now closer to the center "F" mark, retard it a hair more to match the other cylinder.
