wherearewe
Rub on Ya Titties
This is not an old thread...................3 or 4 months is not very old, threads come back to life after years sometimes.
Its fine for HHB to say just install the PMA rotor and then find/mark TDC. What happens if you need to remove the rotor, say to replace a shaft seal? How will you be sure that its replaced correctly? I suppose you just take the time to find TDC with the crank/pistons again.
If you sell the bike, the next owner may pop off the rotor at some time and not even be aware that that he would need to find TDC each time.
Using a proper size woodruff key ensures that no rotary index can change, and that any present or future owner will not have the ignition timing go out of spec.
I agree. In hindsight ill admit its worth taking the time to make a key. Its one of those things you do once and thats it. However the PMA rotors are unmarked, so even with a key when you first install it you would need to be able to accurately find TDC using a stop etc. Once its done that first time though its good to go.
