yamahammer
Didn't dyno the bike yet, this morning I adjusted camchain, checked cam timing(slightly advanced), set valves(.003/.006) compression tested (lots of compression, cold), static and dynamic timed ignition to stock marks, synced carbs(very easy with cvks), adjusted the chain, set the tire pressure and hit the local hills with a friend on a vstar once it warmed up outside. I kept it in 4th and pulled one of our local grades and just pushed past the vibes and revved the snot out of it. The 1300 walked by me but that's not surprising. Still, I managed to keep 95-105 mph up a really long straight pull. I revved it until the clutch started to slip, it sounded like heaven. It has got some impressive power up in the rev range, but lots of vibes. I think all is right in the world. I'm probably just being unfair to the old girl. My last bike was a vstar 1100 that didn't vibrate hardly at all, and the common crankpin design of the v twin means no rocking couple effect. My other current bike is a GT1000 ducati, and it's well engineered and very refined, same common crankpin principle there. I must just be a common crankpin fan.
Hope you all had a good holiday, thanks for your input.
