yamahammer
I got the bike out with the newer cvk's re-jetted with the 40/140/JJJ synced and running really well, did some calculations with the help of a roadside radar detector (my tach and speedo skip like crazy) and found my torque peak to be right at 4,500 rpms. That's where the engine runs out of steam, stops making power, and starts to vibrate more than is tolerable. It's a rephased 447 with an 80mm Mikes kit, 447 cam, stock exhaust, and cvks. My timing is slightly retarded to match the 18/30 final drive ratio, but both cylinders are spot on with a newtronics system.
My question for you guys is, does that sound about right for a rev ceiling? It was a few hundred rpms lower with the bs38's but the curve felt the same, the cvks are just snappier and rev more quickly. When it was a 360 and second oversize it seemed to like to rev higher than that 5,500-6,000 rpms and developed a "balanced" feel under high load where the primary and secondary forces seemed to compliment each other, the big bore rephase seems to like to be lugged more and is happier at low to moderate load.
Is this everyone else's experience as well?
BTW, I use this calculator http://www.nightrider.com/biketech/calc_speed_rpm.htm it is very easy/helpful.
