ok.
So.... I dug out the o-ring and washer on each carb, set to 5/8 out. Runs awesome. I rode it around the block,(3 miles) and idle dropped it. It was almost spot on. Im very impressed how smooth this bike has become.
Note---all you guys with bad vibes should be taking notes here.
I ran it again around the hood, and really gave it the beans!! 5k was all I wanted to push it in 5th gear, but it feels very smooth, taking into consideration the age and design of this bike.
Although, at 5k rpm I was hunting for another gear. I think the chain is fubar, so when I get around to that, Im going to go 32rear sprocket to lower the upper rpms. I don't want to get a bigger front sprocket, as on my 1980 chop with a 520 chain, I see some dings in the clutch pushrod from the chain. It has a 18 th on it.
I also did some polishing on the cases.
[/URL][/IMG]
[/URL][/IMG]
The alt side was easy to take off, so I ran it on the buffer, but the clutch side stayed on. 1,000 grit emery, then one o them foam balls in a drill really perked it up. I stripped the dipstick too, and polished that. Its too bad someone used pliers to loosen it, leaving teeth marks.
