Sold / Found / Inactive - TX650/TX750 front 2 piece 295mm brake rotor
it is wholly possible to disassemble the front brake disc( rotor) and get the steel disc surface ground, i did it on my 1973 XS
at the same we set the disc up on the CNC mill and drilled the 8.5mm holes
zoom in the picture you will see the disc work
the advantage to getting the disc absolutely flat, is much better braking, we took around 0.006'' of each side ( 6/1000s of an inch) the linit is much more than that, in fact most modern discs are only 5mm thick
i am sure i have one, but the postage to Canada would be really high, i will look it out anyway for you
i think its drilled too
Thanks, and yeah unfortunately shipping to Canada is a bit of a PITA at the moment, but I'd be willing if the prices isn't too high. You can DM me if you find one you'd be willing to part with. Your bike looks great btw
If that doesn't work out, I have one from a '74 TX that is quite decent you could have for essentially the same.
