Unable to separate carbs!
Airwolfie
XS650 Guru
United Kingdom
I can't seem to undo the Phillips screws holding the two carbs together, you know, the big L-shaped bracket. I have tried penetrating oil, heat, screwdriver(!!), but I'm very reluctant to use an impact driver. I'm worried I may crack the cast ally body.
They are the BS34's off an 81 Special.
Is it at all possible to strip the carbs while they still together?
Bear in mind this is my first ever mechanical endeavour!!!
Thanks for the quick reply!
Got one of those, thanks! I really did want to strip them completely so I can check all is OK.
Will have a go at it!!:thumbsup:
When you put it back together, do it with screws that look like this.
