So, still having charging issues. The rotor continues to ohm out correctly. Headlight comes on after cranking, which indicates to me the alternator is putting out, but charging output is minimal. I checked the reg/rec and the diodes come up good, 7 ohm forward bias, infinite ohms reverse bias. 9 VDC to the rotor, which was all the battery was able to supply, so it seems to me the rotor is not getting short shrift. This indicates to me that the ground path is the problem. On the last ride, the battery was dying, but revving the motor resulted in the headlight coming up very bright.
I was thinking I could continue to use the stock regulator for rectification, but use an aftermarket VR38SB for the regulation. Am I correct in assuming ( which has gotten me into a whole world of problems lately....) that I can simply splice in the green and brown wires to the separate regulator and have the two units do a tag team with the rectifier for charging? I hope so, since it would be a simple addition. This unit tucks nicely inside the plastic box for the security chain on my 83. A notch for the wires from the pigtail and a good ground lead and you wouldn't even know it's there.
