Okay, guys... the old seals came right out with the tip of a sharp knife, and it became readily apparent to me which seal will go where upon reassembly.
In terms of cleaning and inspection, the mating surfaces of the pistons to not appear to have any scoring, and there was no leaking since I have had the bike. Cleaning-wise, I have just sprayed the bits with brake parts cleaner and wiped everything off with a clean shop rag. I wanted to ask about surface oxidation and/or rust in or around the seal troughs. Since there was no leaking before, how much of the discoloration that you see in the pictures is acceptable upon reassembly? It seems to me that attempts at removing it with anything but a rag and cleaner could compromise fit; I'm afraid to go at them with anything sharp and hard. So, how far do I go, and how clean is clean? The inside of this caliper will never be brand new.
Also, the Haynes refers to only two bridge bolts and their torque ratings, but there are four. Do the torque ratings refer to both the inner and outer bolts? I also noticed that my old pads seem to have a shim-looking thing... almost pointlessly thin... but the new ones do not. And the Haynes has no detailed information on how to reinstall the pistons and pads in terms of how far to press them in, etc.. Tips appreciated!
Please, if you will, have a peek at the pics and tell me if you think I'm close to reassembly after some more washing and blowing out with air.
Thanks!
TC
