Make sure you anti-seize the bolts that hold the caliper together so it comes apart easy next time (if there is a next time). And anti-seize the entire length of the bolt, not just the threaded end. That will protect it from corrosion.
Got it, Gordon. May be assembling tonight or tomorrow.
pregrid, what is the DOT rating on that stuff? I got the 3 as indicated for my M/C... not synth, though.
TC
TeeCat, no anti-sieze on anything that could contact the brake fluid. It is petrolium based. You can use plumber's goop, or, better known as pipe dope. That will seal easier then the teflon tape, and will work better. I use it on all pipe thread joint's, like my air tool fitting's, brake line to wheel cylinder's, etc. Usually, if you just put a cap on the bleeder nipple, it will keep it free, not only will dirt and water not get in the nipple, it adds a nice 'touch', esp. if you find a matching set. BTW, the plumbers goop can be found at Lowe's for a dollar.
