VM34 flow problem
tonyc
XS650 Guru
Bakersfield, CA
Hello group. I had a leak around my fuel lines and sin
ce I changed lines I have not any flow to the carbs. I have tried with and without filters. Any suggestions? Thanks for any help Tony C.
Posted via Mobile
Are the new lines longer? If they are kinked, or if the lines get above the petcock enroute to the carbs, they may not flow well.
No kinks, I can take the line off the carb and they flow. Lines are the sane length. Thanks Tony C.
Posted via Mobile
I found my flow problem. When re-assymbling the carbs I put the floats in upside down. Problem solved no leaks and runs great. Thanks for suggestions. Tony C.
Posted via Mobile
Posted via Mobile
Posted via Mobile
