cmattina1
So, i've been doing some research, but this is has a few different variables so I can't quite pinpoint it.
As I said in a previous thread: I had some BP6ES plugs in, and the left side was all gummed up with oil when I took took it out after 300km (180 miles?). At this time I had the mixture screws OUT 1 1/4. It still had a spark, but I wanted to experiment a bit so, I put in some BP7RES plugs and put the mixture back to factory spec (1 1/2).
The right looks pretty good (bit carbon fouled). However, now the left side looks to be carbon fouled (rather than oil fouled). It still runs fine (good, i'd like to think). The only thing I found a bit odd is when I first start it up, the left carb will pop (both by sound and visually) 2 or 3 times and after a minute or so of idling it doesn't pop any more (the right carb doesn't do anything). There is also some decent backfiring (sputters) as I decelerate, though I have control over that depending on how much gas I give it as I gear down (i'm a new rider, so I'm still refining this skill)
The jets, as far as I know are stock, but the there are pod filters on, would this result in carbon fouled plugs, (having too small of jets)?
Also, perhaps it possible that the plugs were always being carbon fouled, but the left side was covered up with oil, which is now solved by running the bike a bit more (if it was sticky valves or rings).
