Maxx650
Hey everyone,
I've come across an electrical issue on my bike, here are the facts:
Firstly, my 1979 xs650 special has recently sat through a couple big showers here in Austin in the past 2 weeks unintentionally, so it has gotten wet but for the most part kept dry after learning of these issues.
Currently I can turn on the key with engine in 'off' position. Wait 5-8 seconds for the neutral light to grow from very dim to its full potential. Then flip switch to run position - sometimes neutral light dims / cuts out and I have to wait / continue toying, sometimes the light stays at full potential. When it's at full potential in run position I can kick start it... When riding it often dies while down shifting, perhaps due to low rpms? I also had some random issues like my left blinker coming on randomly while ridin. Now using the blinker will kill the engine.
I have tried trickle charging and doesn't seem to make a difference. The battery was purchased from mikes about 5 months ago. I'm not really sure if there is a short in my wires or something with my coil or what, I'm pretty lost.
So.. Anyone know what's up? Alternator? Ignition coil? Reg/rect? I'm lost and you guys are always excellent. Thanks a lot!
Maxx650
- About 2 weeks ago I had trouble getting my headlamp to come on. I could get it to come on after twisting/squeezing/manipulating one of the couplers (6-wire plug) under the right side cover.
- About 1 week ago this progressed into affecting main power as well - with key turned, I couldn't not get a neutral light - when I did see a neutral light it was weak, grow/flickered and then eventually went to normal/maximum brightness. I could manipulate same coupler and get in good position. At this point I lost electric start abilities but could kick it.
- As of this week, my brother (electrical engineer) and I rewired the connection at the coupler thinking that is what was causing the issues. They are now 6 individual plugs.
- Now the problem persists still. However, I now know that in order to get power/a neutral light I cannot have one of these wires connected (dark green to dark green) - I figured when I was manipulating the coupler I was actually disconnecting the contact of that wire pair, perhaps. I think this may be my headlamp wire as that is a component not coming on when I manage to kick my bike.
- Battery measures 13V off and gets up to 13.5 when revving [NOTE: values uncertain.. taken with a crappy multimeter]
- My fuses don't look blown but when measuring with ignition switch on (not engine running) they only measure like 4-6V across. All measured at 0 ohms so I think not blown.
- Electric starter only goes "click" before killing the power and I watch the neutral light grow for a few seconds until it gets bright enough to know the bike is getting full power
Maxx650
