73novaguy
- Messages
- 86
- Reaction score
- 0
- Points
- 6
No. A standard Harley hub will have 5 bolt pattern on both sides. One side is smaller thread pitch because they have larger bolts on the drive side. Just type in Harley Rear Hub and see what you come up with. I gave 50 bucks for an entire wheel with junk outer rim. As far as offset. The nice thing about Harley is everyone one and their brother wants to customize. So I'm going to use a flat sprocket with a spacer to get exact. I'm also running the 1/4 offset front though to.
When looking for one, they all have the same bearing od but around 2000 Mosel year they switched to different rear axle size. Some are 3/4 and some are 1 inch. Mine was a 1 incher so I bought some single row 3/4 bearings and turned the length of a stock Harley axle down so it would fit myRadian swingarm. The Radian swingarm was also machined out to 3/4 fir the axle. If you plan on using stock XS swingarm you should be able to get the conversion bearing easy enough
