bloodhound
their is a recent section on its weight on the garage. I know the RD and the sparks rotors are lighter and make for better riding.
I've done everything you can think of .. and it's still a heavy beast !! . If you are going to run mags, you may want to invest in some magnesium after markets if you really want to cut down on the weight thing.....
Or you could do this ....
http://www.650motorcycles.com/XSR1.html
Mule, that's a very methodical way of doing things and great advice about how to go about reducing weight on an XS650, or any motorcycle for that matter.. You wouldn't happen to have a large list of the stock weights of various XS650 parts would you? That would be a great start to the parts weight index. I would start it, but it's going to be damn cold in the Midwest for the next couple of days and it would take a lot of propane to keep the garage warm. Need to wait for it to warm up a little bit.
Mule, that’s a very methodical way of doing things and great advice about how to go about reducing weight on an XS650, or any motorcycle for that matter.. You wouldn’t happen to have a large list of the stock weights of various XS650 parts would you? That would be a great start to the parts weight index. I would start it, but it’s going to be damn cold in the Midwest for the next couple of days and it would take a lot of propane to keep the garage warm. Need to wait for it to warm up a little bit.
As to specifics, the front end I did on the "Jason's Chassis" on my webpage uses TT500 triple clamps (bored to 38mm) and FZR600 fork legs. That took 12-13 lbs off in one shot! How's that for weight cutting?
I'd say that's pretty damn good!
Having another bike to ride when doing any work on any motorcycle is a must in my book. If there's not at least one complete running bike in the garage, what are you going to do on that gorgeous summer day when your buddies come over and want to go for a ride? I guess not having a back-up bike is good motivation to get your projects done quickly. But like you said, it'll probably make you cut some corners.
I found this for the SR500: http://www.siue.edu/~rsutton/SR/weights.htm Must be incomplete or inaccurate though because my SR500 is missing a few parts and still weighs more than the total given. Unless that's just the difference between the dry weight and the wet weight (gas and oil) or me not weighing it accurately.
I'm sure Mule will chime in as he is the one who guided me thru this. For rotors he used a beull rotor. I kinda wanted to stick with the race look and EBC makes a wave rotor for Harley that I'll be using. So by that you should be able to tell I'm using a Harley rear hub as well (thanks Mule) but I had a hard time finding a used aluminum Sporty hub. From what I've read and asked the Harley guys, all Harley hubs were the same with the exception of the Sporty being RSD (right side drive). So my aluminum hub is off from a 2000 Touring Hatley. It's still a 40 Spoke hub. And I'll be using a Sprocket Specilaties sprocket. They offer them with "race hole lightning" and down to like 28 teeth, along with the "wave" rotor from EBC
So for the sprocket, you don't need any offset? A quick look on ebay shows a bunch of different rear hubs for harleys. Do I need to look for one with 4 mounting holes on one side and 5 on the other?
