Hello all,
I have been lurking for a while and have learned a ton from this site. I have a 1980 XS650 with TCI. It was running perfect up until a few weeks ago. Every electrical test I could find in the manuals or on here has been within specs. The brushes are fairly new and barely worn.
When everything is hooked up, it charges but runs like total bunk. It has a lot of trouble making it to 2500 rpm. When I unplug one set of the stator to regulator white wires it will run like a champ. It also runs great on just the battery, with the charging system disconnected.
I have a spare TCI, rotor, stator, reg/rec, ignition, kill switch, and I have tried them all and they have done nothing.
Any hints? Suggestions? Questions? I am at a loss.
Thank you for your help
