I replaced my headlight bulb several months ago and all has been well until recently.
The regular/daylight bulb stopped shining, but my brights work fine. Thinking maybe the dim bulb went out, I connected a good lighting reserve unit to see if it would switch. Nothing.
Thinking it could be charging issue I checked, charging just fine. Again, brights work fine and don't even noticeably dim when blinker, brake etc are turned on. Engine power is normal too.
Following the charging system lead I took out my "normal" safety relay and put in a bypassed version. The regular headlight now works however it is extremely dim and if I press brake or turn on blinker it dims out completely. Brights still work as normal.
Ideas? Just a loose wire? Poorly bypassed safety relay and bad other safety relay?
