Patches,
I actually am moving soon, so I'm holding off on making the real stand for it. Taken apart, the big piece is about 260lb and the little is about 240lbs. The stand is about the same height as the back of my truck so I slid them out of the truck and onto the stand. Then I used a 6ft 2x4 as a lever under the bottom brace to lift each side and kick a flat moving dolly under each brace. It's actually not that bad to move around. I do have an 2 ton engine hoist if needed. There are 1/2"-13 threaded holes on each corner of the plates. You can make nice T-handles for sliding the plates around and picking them up off the floor with 1/2" bolts and a piece of 1/2" round bar welded to the top of each bolt.
