hotrdd
XS650 Junkie
Posted this in another thread but haven't had any replies. After going through the carbs and doing the cam chain tensioner, valves and timing the bike seems to be running worse. I feel like I have went through the engine and looked at everything but I'm sure I'm missing something. I am going to go back through the valves again since I only had a .005"and .008"feeler gauge when I did the intakes. This means the intakes could be anywhere between .005"and .007". I also took my single air intake off to make sure it wasn't playing into the equation. What would you be checking next?
1) Fixed the carb issues with the needles being in different spots and a missing diaphragm return spring.
2) Took the air cleaners off in case they were causing issues with the carb. Sync. (So the carbs are running without a filter)
3) Set the cam chain tension adjuster as per the website.
4) Went through and adjusted the valves.
5) Moved the Main jets up one size on both carbs.
6) Set both mix screws to 1.5 turns out.
7) Warmed the bike up.
8) Synced the carbs at idle (But as the RPM's climb the right carb has about 10"of more vacuum on my ATF manometer)
The bike is still on the stand but it seems to be running even rougher. As the RPM's go up I'm getting rapid popping from the exhaust but it's not very loud. The bike also seems to be shaking more now than it did before and making more engine noise.
What am I missing?
What am I missing?
