xjwmx,
Here is a picture of the complete assembly as I was installing it in my '81/H three years ago. The noted changes were done before final installation:
The two mounting holes line up with the stock threaded holes on the center frame. The upper cut corner was to clear the
left side cover and the lower cut to clear the swing arm.
(Edits)
The rectifier that is wired to two of the white wires from the stator draws about 12 Amps under full load conditions. The drop across the diodes is about 1.2 volts, so that is about 14 Watts for each wire. In such a small surface area, it does get hot, but it is well within the spec for the rectifier, which is 25 Amps. These are estimates, and you may come up with a more exact figure, but suffice to say the rectifier gets hot and has to be heat sinked.
Do I want to discuss what is meant by hot, a relative and subjective term? No.
Do I want to discuss the theory of heat sinks and what size heat sink would be optimum for this application? No.
I used the heat sink compound from Radio Shack. Heat sink compound does not run. It tends to solidify.
Do I want to discuss whether or not the heat sink compound runs when it gets hot? No.
This setup has run on my '81/H for three years with no problem. I have the same rectifier setup on my '78/E for 10 years. I have no idea what you consider to be reliable, but in my world, that's reliable.
If you look closely at the bottom rectifier you will notice that one set of diodes is not used and is available as a spare should any of the others short out.
Here is a picture of it installed in my '81/H:
