1. Dismiss Notice
    Dismiss Notice
Discussion in 'The Garage' started by I am Carbon, Nov 24, 2013.
Tags:
  1. halfmile
    halfmile XS Builder XS650.com Supporter Top Contributor
    1,182
    3,807
    263
    kansas
    Over the weekend I picked up a unmolested 80 Special just to get the rear disc brake frame for whatever that is I`m building. Had it VIN verified, insured, titled & tagged in less than 2hrs. A new record for me at the DMV. Started to tear it down to the bare frame but mosquito`s in the garage got the best of me. Maybe tomorrow with some repellent.:thumbsup:
    Boog, Raymondo, buzzword and 3 others like this.
  2. halfmile
    1,182
    3,807
    263
    kansas
    I`ll post this on this thread because it`s 2 stroke and the word "Mate" reminds me of Signal.:thumbsup:
    Caseyhard, thuban, Boog and 4 others like this.
  3. joebgd
    joebgd XS650 Addict
    391
    130
    43
    NY
    How do you remedy that. I'm going to be fixing the spring clip on !y #4 gear as well.
    I am going to push in on the kick start spline as I take the cover off. I never had that cover off so I don't know exactly what it entails, If it does wind up getting out of sorts...?
  4. Mailman
    As long as you’re careful to do that, push that kickstart shaft in as you pull the cover off, you won’t have any problems. If you’ve never had the cover off, it’s likely to be really stuck on there. Just take your time with it and don’t be driving screwdrivers into the gasket surface area trying to pry the cover off, that aluminum is soft and you’ll nick it. I usually start by tapping on a small block of wood placed on the front of the cover, right here.
    The cover sticks out from the case right there, a little. Once I start to get a gap opening I insert plastic putty knives into that space and just keep working it.
    thuban, Boog, YamadudeXS650C and 2 others like this.
  5. lakeview
    lakeview XS650 Guru XS650.com Supporter Top Contributor
    I dribble penetrating fluid along the join plus apply it on the heads of the screws that you have to remove. I tell myself it helps.
    thuban, GLJ and Mailman like this.
  6. Boog
    Boog Traveling Stroyteller
    I freely admit to being jealous of your DMV visit brother. I picked up a Stratoliner last month and had to make an appointment to get it titled and registered; in late August!!! Yep, I'm riding it as is and carry my Bill of Sale. the original title signed over to me and the Virginia DMV form for registration in case I get pulled over. The bike is insured and has a fresh State Inspection sticker on it. This dang Covid delay crap ruins a fellow's mood often...
    thuban likes this.
  7. yamahama
    yamahama '72 XS in Restoration XS650.com Supporter
    189
    244
    43
    Florida
    Reminds me of the 1978 black Special I had like in '79. Nice riding bike.
  8. halfmile
    1,182
    3,807
    263
    kansas
    Well whatever that thing is I`m building is really starting to come around. 100% improvement since yesterday.:thumbsup: In fact the frame is already 95% done. All I have left to do is remove all the unnessary tabs, make new rear suspension, make new seat rails, bend up a new rear frame half, weld it all up, sandblast, and powder coat. Piece of cake.:D TCI from this bike goes in the classifieds.
    80 XS frame 005.JPG 80 XS frame 007.JPG 80 XS frame 008.JPG 80 XS frame 009.JPG
    buzzword, Raymondo, GLJ and 3 others like this.
  9. lakeview
    P O Drilled It, I'll Paint It
    A globby coat of black paint all over the centre is removed; a tidier coat to come.
  10. joebgd
    joebgd XS650 Addict
    391
    130
    43
    NY
    I was considering drilling my front, do you have the tire balanced after? How do the drill bits hold up? I figured they probably need a sharpening every 3-4 holes drilled. And or get like 20 generic bits of the size. What size did you go with? I read a while ago so I'm not really sure, but they should be in area of how thick the disk is.
    I want to go with the spiral look swiping towards the outside. At one time there were templates on here. I'm going to search it..
    That will look sweet when it's painted.
    Boog likes this.
  11. Jim
    Have a look here.
    168 holes with 1 drill bit... no sharpening.
  12. Mailman
    I forgot you did that. you do some pretty nice work! :D
    Boog and Jim like this.
  13. willis
    willis xsive compulsive disorder XS650.com Supporter Top Contributor
    The key to making your bits last is low speed and use some cutting oil. I think I ran my drill press around 550-650 RMP.
    YamadudeXS650C, buzzword, Jim and 2 others like this.
  14. Jim
    1+ on that. For steel you want a slow speed and moderate pressure.... and there's no such thing as too much cuttin' oil. ;)
    Superjet, Boog and timbeck like this.
  15. fredintoon
    Hi willis,
    yeah, BTDT.
    Use the lowest available drill speed speed, flood with cutting fluid and reef down as hard as you can on the feed lever,
    Cobalt steel drill bits work best. I recommend 3 steps.
    Massive centerpunch marks then half size holes then full size holes
    Note that the XS650 brake disk material is tougher than old boots.
  16. lakeview
  17. Mailman
    Changed oil in my ‘77D today, cleaned the filter screens , the sump filter was clean as a whistle, just wiped it off and reinstalled. I’ve got to reinforce a tip from 5Twins here, on the sump plate gasket, I apply a thin coat of anti seize and it works so well, the sump plate simply falls off before I can even remove the bolts! Unlike the first sump plate I ever removed , that I had to beat on to get it to come off. o_O
    gasket with anti seize already applied
    yamahama, ThatXS650Guy, SEd27 and 7 others like this.
  18. yamahama
    189
    244
    43
    Florida
    Let the best-est restoration upholstery shop in town look at my seat pan and cover...wanting him to just build up the foam for the seat..He said for just about the same as what I would have importing a molded seat foam but he was probably loosing $$ on it. Sort of sounded good to me. Have some rear spokes on the way.
    Boog and Mailman like this.
  19. WideAWAKE
    WideAWAKE Single Fins and Twin Cylinders
    Not on my XS but a twin nonetheless...
    built a fiberglass battery/electrical tray for under the seat jump and a little under seat tool/paperwork dish. Lots of dirty work on the little canyon buggy - all still in the mock up/modify stage.
  20. lakeview
    34 mm fork rebuild
    For the 73 TX 650, was not too difficult with reference to MaxPete's thread on same, especially the squished tube tool hint there, big shout out to P. O. who had done the hard work of draining them and breaking loose the Allen bolt.
    Mailman likes this.
Share This Page
