1. Dismiss Notice
    Dismiss Notice
Discussion in 'The Garage' started by I am Carbon, Nov 24, 2013.
Tags:
  1. Mailman
    So how did you do that? Fog a little silver over the black?
  2. Machine
    Machine Race the wind Top Contributor
    Yes I did, if only just a few larger speckles didn't go that far I'd be bragging bout it. It was fun for a first try and maybe good enough for this rider..
    realgoodtexan and Mailman like this.
  3. lakeview
    lakeview XS650 Guru XS650.com Supporter Top Contributor
    Emptied Two Engine Stands Today
    Getting all the bits in one spot. The motors for these two were taking up space, so I bolted them in. The Special will get put together to go to a new home, but the 76 may stick around for a while.
    Frames were painted last fall.
  4. azman857
    azman857 '80 XS 650SG Rider XS650.com Supporter Top Contributor
    Not much. Been too blustery and windy lately for me to ride. Had some rain too.
  5. Busted_Knuckles
    Busted_Knuckles XS650 New Member
    2
    7
    3
    Utah
    New to the forum, new to the XS650.
    Re-torqued the head bolts. Spent 15 minutes trying to find that “front” bolt. Maybe it’s hiding behind this oil tube? Take it off, no bolt. Look at torque sequence chart, turn it 90° counter clockwise, and BAM! Suddenly it all makes sense.
    Ha ha, I’m such a dumbass. Let’s just say that this isn’t a 15 liter diesel, my normal project.
    TwoManyXS1Bs, nj1639, Mailman and 2 others like this.
  6. 5twins
    20,889
    13,600
    813
    I installed some Ferodo Platinum brake pads on my '83. They're not fully bedded in yet but I'm hoping they'll work just as well as they do on my '78 once they are .....
    [​IMG]
    [​IMG]
  7. Machine
    Interesting. Hope to learn from your experience as a long time OEM Sumitomo believer.
    jetmechmarty likes this.
  8. 5twins
    20,889
    13,600
    813
    Yes, the stock pads are good and I do like them. When I first put the Platinums on my '78, I didn't feel they made much difference. But now that I've been running them for several years and they're fully bedded in, I think they are better. Now that I have two bikes to compare side by side, one with stock pads and one with the Platinums, it was easy to tell and feel the difference. The bedded in Platinums definitely stop better.
    These used to be the pad 3M at 650Central said was best. He now sells a sintered metal pad that he says stops a bit better, but it's harder on the disc. I bought my 1st set from him as he's one of the few sellers. They are premium priced from him though, about $35 a set, but I figured what the heck, they're supposed to be one of the best. This recent set I ran across on eBay for around $20 so I jumped on it.
    Mailman likes this.
  9. nj1639
    nj1639 Paleo-simplistic Top Contributor
    I threw mine back on, third time a charm? Considering it as a deflector more than a windshield may give me a different perspective on the function and a tolerance for what it's not.
    Machine and lakeview like this.
  10. Fresh oil change tonight for the TX, chain lube, shake down ride, and about 100 mile ride planned for tomorrow. Meanwhile, my new last summer 2019 DR650 sits waiting with no insurance as I am enjoying my first Yamaha so much I can't think of not riding it!
    nj1639, lakeview and Raymond like this.
  11. yamahama
    yamahama '72 XS in Restoration XS650.com Supporter XS650.com Supporter
    301
    449
    63
    Florida
    Humm, looking up at the 5twins post, mentally noting weather I should try and turn down the surface of my stainless disc...Rather not lose material and get close to the limit as I save the old pads ft. and rear that look great that are sintered. But, I am here as I have my butane torch out sitting next to my ft. forks to get the seals out, and start to sand n polish. See how some new polish pads wok on my 1 HP grinder wheel. Then move onto the other case 1/2 and rear hub stuff...if I get it right. Oh, logged on the see if I might use little crow bar on those fork seals if I recall someone did effectively.
  12. yamahama
    301
    449
    63
    Florida
    One fork seal took 9 mins in a boiling sonic bath and came out normally. One took 16 min. before it was ready. Looks like the easy seal was a replacement and the knuckle head was an original. Getting the hang the polish wheel. Stopped to wipe off that dk.grey polish stick with KruddCutter, soap and water..throw a few beers and a big bottle of sangria in the fridge. Going to switch pads and do a pass with the white compound, clean and put a few drops of this stuff on The paint sealant in the middle.. Sure it will look good after a few beers.:cheers: P1010147.JPG
    >> That paint sealer is a bit different from the last batch I had. It's water based. One I had before was not and a few drops on 3 fingers would coat this entire lower. Left it to dry and looked so good...after that#2 beer, replaced some artwork on the wall with it.
  13. Machine
    Rattle canned. Never before attempted a "color match" anything. Not perfect but hey, neither is the tank or anything else
  14. Mailman
    Looks good to me!
  15. bosco659
    bosco659 XS650 Junkie XS650.com Supporter
    Looks fine. The parts aren’t side by side and light will hit the parts at different angles so it will look great when assembled. Nic job!
    Mailman likes this.
  16. That rattle can paint job is nicely done!
    I rode out with a couple of buddies to Jordan River, BC, from Victoria today - about 115 miles round trip. Heated vests were a must! Bike has 1113 miles on it now, since the new top end (May 2020), and is feeling better all of the time. Will do a separate rebuild thread with lots of pictures soon.
    Marlin72xs, JesseeS, lakeview and 2 others like this.
  17. Machine
    Sunday, Anxious to feel how the double disked 79 front end feels, I poured in the brake fluid and started manually bleeding the whole system. Once the calipers did fill enough with the bubbles to start acting hopeful it became apparent that the banjo fitting at the original 79 master cylinder wasn't going to make it. Leak ! I could even hear it
    :poo: tried a couple other used copper gaskets, No way. So back off it came for a fresh face on the sealing surface today.
    Vertically aligned using an appropriate size pin in the thread minor. Carefully positioned and clamped. A 3/4" end mill at 900 rpm slow plunging only resulted in a reasonable finish.
    Little fresh paint. Squished in better copper gaskets.
    Letting all the components sit a day to get to know each other. Hope it all holds a good seal and pumps up nice next time. Hope to post how the front brakes feel !
    -R
  18. Mailman
    That’s a nice little machine shop you have in your garage! :D That ought to do it!
    bosco659 and Machine like this.
  19. Machine
    Monkey business :)
    We'll see how it tests out. Yes, I'd like to have new lines after it's proven..
  20. Niels B
    Niels B XS650 Enthusiast
    finally got my ‘75 XS completed, as stock as possible with new wires old exhaust - refurbished carbs etc.
    76CF63AB-E877-4C8F-ACA3-F79692F363EB.jpeg 30AD9851-7718-451C-A7A7-3B73FB7AB7D0.jpeg
Share This Page
