what the hell did I do wrong with the brushes
Thanks got it cleaned and put back together
The correct way :thumbsup:
Thanks to you all
Cleaned and put back together properly
I removed the 2 long screws but it didn,t want to come off so I stuck my head underneath and there was 1 more screw that needed to come out
Mission accomplished
If you mean that little screw holding the wire loom clamp to the stator housing, no, it doesn't need to come out.
Looks like you need a new cover gasket. This is one of the few places I apply some sealer, but not for sealing purposes really. I only put it on the cover side of the gasket and do that so it comes off stuck to and with the cover when I remove it. I coat the other side, the one that faces the engine, with anti-seize so insure it won't stick.
I screwed up with this gasket, not replacing it when a small portion broke off around the outside of one of the screw/dowel holes, and look what happened. Yep, it cracked the cover .....
These sorts of tips are invaluable - I would of just ignored that missing bit on that gasket. Thanks a heap 5twins.
Regards Ray.
WoW you wouldn't have thought the cover would crack like that
I have a new gasket that I may use to make another gasket using it as a pattern
Is there a minimum thickness for the gasket material
I have 3 or 4 different thicknesses of gasket material on hand
Since that gasket doesn’t have to hold oil in, it can be made out of practically anything. I made one out of a cereal box once, just to see if I could. I ran it on my bike for over a year before I finally damaged it.
I'll just use the thickest gasket material I have and I should be fine
I've been making gaskets for the sump plate on a few of the 650's I've had and as long as I make sure that the surfaces are good and clean I haven't had an issue
In fact everyone I have opened up I'm sure the gaskets were the original ones (stuck tight)
Hell back in the mid 70's I didn't even know enough to remove the sump plate and check the screen I just changed the oil and kept putting miles on it
