You can use the '75 hub but not the '75 disc. The '75 disc has a different offset. You will have to use the '75 hub with your '81 disc and '81 caliper. The '75 caliper will not fit.
Check the backside of the disc mounting holes on the '75 hub. On some early hubs, these were blind holes (didn't go all the way through). Check the length of the disc mounting bolts. Run them in finger tight to make sure they go in tight enough before bottoming out. If the bolts are too long, they can break the back out of the hub when fully tightened.
