EDIT: having taken a few out to see how inners fit as outers I realize it doesn't even want to line up. I'll leave the original post as it was. end edit.
I've just laced up my 18" rear wheel using stainless spokes, the pattern is good, none of the spokes are bending or interfering with each other... in fact they're not even touching where they cross over.
The original spokes made contact at the crossover point and when they came out through the holes in the hub the bend angle made them lay flat across the surface of the hub but my new outer spokes come away from the hub at the hole then angle back toward the hub to touch the edge only. It fits ok, it just doesn't lay the same as the old ones.
I started with the short head spokes on the inners and went from there. Haven't trued or over tightened the nipples yet, they're just tight enough to take up slack and play.
Is this normal with replacement stainless spokes or did I get my inners and outers the wrong way round? I feel like I did it correctly, just want to check though.
I laced it using a combination of drawings I made for the pattern and info from here http://www.xs650chopper.com/2009/12/how-to-lace-a-wheel-from-scratch/
