Normally if a pivot bolt is not cooperating I would lube and walk away, giving the penetrate time to work.
Last weekend I was in a bit of a hurry.
Removing the nut and grease zert I would oil each side, block and tap, oil, block and tap,oil, block and.....well you get the idea. I wasn't getting anywhere once the threaded end flushed with the frame. Thanks to forum and my packrattyness.
I found a solution that ended with a bolt out and the threads in good shape.
Following 5twins advice I have replaced every straight sided grease zert I come across.
The things are a friggin mess my gun doesn't grab the straight sided ones and grease just balls out the sides.
Then following gggGary's advice I removed the ball and springs for use in the 34 carbs.
Still I have a bit left so I chunk things like that in a can.
I located one and put it in the end of the pivot shaft to protect the bolts threads(inner and outter).
Perfect to hammer on.
