LTGTR
I am considering buying a compression tester but have read that you may get varying and "low" results if you have one with the valve at the gauge end of the hose instead of at the "connect to the engine" end of the flexible hose. The reason given is that because its a small engine the volume of the flexible hose effects the reading.
I have read lots of posts in this forum about compression testing, but that issue hasn't been mentioned.
Geoffxs (equivalent of Mikesxs here in Australia) sells one that seems reasonably priced but has a longish flexible hose in the kit and looks the same as the one Mikesxs sells.
Has anybody had experience with different testers including the one Mikesxs and Geoffxs sell and can advise on the correct one to buy please.
Kind Regards - Ray.
Kind Regards - Ray.
