YL82
Perpetual Restorationist
My ride is a 1976 Yamaha XS650C.
I recently installed a Pamco, a new advance unit, new advance rod, new Iridium spark plugs and spark plug wires and the high output coil. I'm no mechanic, but I did the install myself in a methodical manner.
The bike started up just fine , but I had to abort setting the timing since my fuel petcocks were leaking terribly. I then removed the fuel tank, removed the non-vacuum petcocks and rebuilt them. I then added Visu-Filter Slimline fuel filters (with sintered bronze elements) and did some other unrelated work.
After I reinstalled the tank, I hooked the fuel petcocks back up and refilled the gas tank with about 3 gallons of gas.
I decided to charge the battery since a few weeks had gone by since I had installed the Pamco.
I have a Battery Minder (Model 12117). See attached image.
I recharged the battery overnight.
One thing that I did do was to turn on the switch to ensure that I was in neutral. I left the switch on for a minute or two (while the battery charger was doing its thing with the battery still installed and wired up in the bike).
Starting: Starting was difficult and I had to push Start button numerous times. I noticed a little white smoke coming from under the fuel tank on the right side. I removed the fuel tank and checked out everything. Didn't see anything amiss.
I then tried again to restart the bike and got it started and let it run while adjusting the idle and allow the engine to warm up. At this point, I revved up the engine some to keep it going and noticed a clanking noise - which I think was mis-timing.
I then turned off the engine, then tried to restart the engine and a profuse amount of white smoke came out from right side below tank.
I noticed that the Pamco (cover was removed for setting timing...) was hot and that the advance unit cover was very hot.
Have I somehow fried the Pamco? Could I have overcharged the (new) battery causing a problem with the ignition system? Did turning on the switch during charging have anything to do with my current dilemma? Where the hell is the white smoke coming from exactly?
I've tried to provide a detailed timeline of the things I did along the way, so hopefully someone can figure out what I did WRONG and help me determine how much damage I actually did and what parts I need to replace.
Notes: At no point did I disconnect a spark plug... Pamco is well grounded to frame... I did perform the Pamco Pete test for free movement of the advance mechanism and the weights snapped back fine...no binding...
More info: There is a possibility that the 5 gallon gas can that I used may have had some water in it. The plastic can had been sitting empty outside for a few days and had the yellow cap installed over the spout. I took the can to the gas station and pumped in 3 gallons. Perhaps condensation had formed in the can..? A post I read about white smoke led me to this possibility. Water in the fuel tank can cause white smoke to be emitted from the carbs.
Thanks!!
Thanks!!
