Last summer, after replacing the entire charging system on my XS650, I decided to buy a handlebar mounted volt meter. Today I found the cute little volt meter in a box of parts and decided it's time I finally hooked it up. The instructions are as follows:
"can be easily wired into any point in the system (before a switched load is best)."
My question is: while it can be easily wired into any point in the system and preferably before a switched load, where do you believe is the best place to hook the wire into the harness?
For example, should I wire it at the fuse box, the wire that supplies power to the headlight switch, the wire that powers the low beams, the wire leading from the key switch to the ignition system, the wire that supplies power to the starter button, the wire that feeds the kill switch or where?
Thanks for your help.
