Scott
I replaced the handle bars on my 81 XS650 so I could mount a new m/c to start get front brakes working and no longer have anything when I press the starter button. Kicks over great, but starter button does nothing now. Could this be a ground issue? The new bar is painted black, could that make a difference? I do need to do something with the wiring as the p/o cut off the turn signals and I can't find the positive side of the wires + the original fuses need to be replaced. Lights are wire nutted without a fuse, ignition spade is broken and fuse is wedged into place. Is a replacement fuse panel or wiring harness from Mikes worth the money or should I replace the fuse box myself (that is easy enough) and forget about signals for now?
New at this and want some seat time soon.
