Randy1952
XS650 New Member
Finally getting to the end of restoring my 72 XS2. Left the wiring for the last. I bought a new wiring harness from Mike's, last year and just getting to hooking it up. Having problems with the front and rear flashers. Everything else is OK but can't get them to do anything. Have a new flasher. The flasher just hums when I try to use them. The flasher has 2 wires ( brown and white) power out and brown ( for power in). There is a 3rd connection that never had a wire on it. Says ground on it. Tried putting a ground wire on it but no help. I pulled the blinker switch apart and 1 wire was loose so I soldered it back and cleaned the switch.
Any ideas?
Any ideas?
