jsmith1107
A few questions---on the bottom 2 pictures--the one is from of the PMA and has a green and red wire---based on the top picture the red goes to the Sparx and the green is ground? Also--the red in the picture on top--it goes to the key switch right?
Ok, now the Sparx--it has 3 blades on the end of it--I know the red from the PMA goes to one--what goes on the other ones?
I am using the original left handlebar switches which has the turn switch (green wire to right, brown wire to left signal), the horn (uses pink and dark brown to horn), and high/low beam on the headlight. I have 3 wires left (yellow, green, and blue). I assume yellow and green go to the headlight? What carries power to that switch for the horn, blinkers, and headlight switches to work? The blue?
