GeorgeOC
XS650 Junkie
Hello to everyone. I am looking for a top clamp only, for a '77-'79 Standard. Ideally the clamp would be structurally sound, but doesn't need to be pretty. I would be refinish/painting etc anyways.
I am retrofitting a '76 with 34mm forks to a set of 35mm forks to enable a Brembo swap for the front brake & caliper. I found deal on a complete front end from a '80 Special that was too good to pass up, but the top triple is problematic due to the ignition switch orientation. I believe a top clamp for the Standards within the '77-79 will do the trick.
Thanks in advance for any leads fellas!
