These are roller bearing cranks. The oil system is hi-flow, low pressure. May need to destroke to make room for 2-piece insert rods. You'd have to reinvent the case, crank, rods, pressure lubrication, cam drive. Might be easier to graft an XS650 top end onto a Norton Atlas...
no it i very easy to make the crank case......... no transmission , just the crank case.
from there you can add a bolt on transmission , or a belt drive (snowmobile clutch) or hook it up to a jet pump drive for a jet ski. and the best part is using this very dependable 650 60 h.p. twin cylinder set in an aircraft .
this engine is SUPER VERSATILE !
IT CAN POWER MANY THINGS.............
i was wondering what the steel inserts actually look like......... the ones cast into the bearing journals. . . . .
no biggie .......i am thinking that mine will be strong built anyway ....... like a automotive engine ........ except smaller , super strong etc........
i have thought of this for some time........ i actually will not use this engine for the motorcycle........ but for many other applications .
E`SPECALLY AIRCRAFT & BOAT JET DRIVES .
THIS ENGINE IS TOTALLY BULLET PROOF !
with all of the excess weight of the transmission and other componets that are a part of the stock factory engine ......... it is light enough for the aircraft .
& 60 h.p. makes the scene !
that 60 h.p. will make a small aircraft like the rutan quickie or the hummel go 200+ mph .
