1. Having trouble logging in? Try closing your browser and re-opening it. If that doesn't work, try a different browser or device. The site will be updated soon to resolve these browser issues.
    Dismiss Notice
  2. Dismiss Notice
Xs 650 reserve lighting unit.
Discussion in 'The Garage' started by Red45, Jul 22, 2019.
  1. Red45
    Red45 XS650 Member
    6
    6
    3
    Canada
    hi guys, quick question hopefully somebody will know the answer to. Will the reserve lighting unit from a 1981 xs650 work as a replacment on a 1980 xs650? I would assume it should be the same but can anyone confirm this? The part number for the reserve unit on the 1980 is 1T3-84308-00-00.
    Thanks
  2. gggGary
    gggGary On the road of life I'm a speed bump. XS650.com Supporter Top Contributor
    As quickly found at Partzilla;
    This Yamaha 1T3-84308-00-00 RSRV LIGHTING UNIT ASSEMBLY (Not Available) fits the following models and components:
    Yamaha Motorcycle 1980 XS650G Electrical - 2
    Yamaha Motorcycle 1978 XS750SE Electrical - 2
    Yamaha Motorcycle 1978 XS750SE-31 Electrical - 2
    Yamaha Motorcycle 1978 XS650SE-11 Electrical - 2
    Yamaha Motorcycle 1982 XS650SJ Electrical - 2
    Yamaha Motorcycle 1980 XS650SG Electrical - 2
    Yamaha Motorcycle 1979 XS650_2F Electrical - 2
    Yamaha Motorcycle 1981 XS650H Electrical - 2
    Yamaha Motorcycle 1983 XS650SK Electrical - 2
    Yamaha Motorcycle 1978 XS650SE Electrical - 2
    Yamaha Motorcycle 1978 XS750E Electrical - 2
    Yamaha Motorcycle 1981 XS650SH Electrical - 2
    Yamaha Motorcycle 1979 XS650SF Electrical - 2
    Yamaha Motorcycle 1978 XS750E_227 Electrical - 2
    Yamaha Motorcycle 1977 XS650D ELECTRICAL 2 XS650 E006501- - F
    Yamaha Motorcycle 1978 XS650E ELECTRICAL 2 XS650 E006501- - F
    Yamaha Motorcycle 1978 XS650E-006 ELECTRICAL 2 XS650 E006501- - F
    Yamaha Motorcycle 1978 XS650E-006501 ELECTRICAL 2 XS650 E006501- - F
    Yamaha Motorcycle 1979 XS650F ELECTRICAL 2 XS650 E006501- - F
    Unless you are restoring, that unit is probably worse than useless. It is more likely to die than the bulb who's failure it's supposed to save you from.
  3. Red45
    Red45 XS650 Member
    6
    6
    3
    Canada
    Yeah. I was thinking of just by passing it, probably the best bet.
  4. 5twins
    21,930
    15,493
    813
Share This Page
