- - - So I guess my main question is, based on the parts I listed, and not needing a master cylinder, that should be all I need right?
Hi Fazz,
FWIW, unless you are buying enough stuff from MikesXS in one order that the shipping won't break you, those metric fasteners can be bought at any fastener specialist store, as can single coil spring washers to use in place of tab washers.
Note:- Spring washers have stopped my front disc bolts from vibrating loose ever since I had the discs off to drill them 7 years back.
But as to what else you'll need, a vacuum pump and the patience of a Saint to help you bleed out the brake lines.
