member3480
RICH
I been asked this question many times so I figured I would share this info so that builders are going into right direction.
Many of my builds I have changed to aftermarket wheels so that I could have SPOKE DISK BRAKES front and back. Better stopping power for your XS 650
I was able to go up to a 5" wide rim on the rear and not offset sprocket but most I used where 4" wide wheels. I used a set of FAT SPOKE wheels on a build and it did take a couple tire changes (size) and a little tweek on the frame to get it centered . Now when you go to aftermarket wheels you got to remember the axle size. These wheels are 3/4 " AXLE and your stock XS 650 is 20mm. What I do on builds is order the 3/4" axle plates separate and then I can use a UNIVERSAL HARD TAIL KIT or just cut off the 20mm ones and install 3/4" ones. Sounds like a lot of work but the finished out come is great. I have seen frame with 20mm grinded but you are dealing with a axle that has to track straight.
The aftermarket wheels I buy are online and there are many company' s that sell these wheels NEW at a good price or there are some really good deals on used ones too. If you want names of places I buy from you have to email me because I am not going to give them advertisement on here
Now the fronts are easy if you go to a different wheel and front end. Most 1998 and up SPORTSTER front ends go onto a xs 650 frame with minimal effort and you can get 19"-21"-23" wheels. Again AXLE SIZE-BRAKES-DISK are all easy to get and setup.
Both pictures of these bikes are AFTERMARKET 18" rear and 21" front. White frame bike wheel lined right up. Fat Spoke had to open rear frame section 1/2"
Anyone who need to talk or pick my brain contact me at DADDYGCYCLES@YAHOO.COM
THANKS AND KEEP CHOPPIN
Rich
Rich
